Twin Headlight Bezels
Hi All
below is a picture of my twin headlight Bezels Made from Aluminium Size: W 28mm X H 11mm X D 3mm Tip: For the Lenses I have cut the original King Hauler Lenses in half and they fit perfectly. With the LED I have used a short piece of 5mm ID tube glued to the back to hold the LED, I have also used a hot glue gun to mould a bucket around the LED, both work great Mill Finish $10/Pair (no lenses or bucket, suits 5mm LED) Polished Finish $15/pair (no lenses or bucket, suits 5mm LED) http://i206.photobucket.com/albums/b...htsurround.jpg Postage with these can be a registered letter, I will get a quote if you are interested. |
Re: Twin Headlight Bezels
Got as couple set of these to day and they are GREAT..
Thanks for real quality.. Wayne |
Hi Wayne
Great to hear you finally got your parts, Post a pick of your truck when you have them fitted, be good to see them! Cheers Paul |
I will agree totally with Wayne. This set is great and look forward to installing them in my next daycab and will get pics asap along with the new grill.
Hi Paul ,
Nice work can post some pics of the parts once machined for the benefit of all viewers .Thanks mate may be front and back pic with rule showing the size :) Kev |
yes will do, hard to show in a photo though........too much glare from the shine :D |
Hi All
I am now offering an old school round twin bezel, same price as the square one $15/Pair polished. I will no longer offer the mill finish on these as they look half done in the mill finish so I will polish as std. I will make a run of both today and then take a photo of each next to a rule so that you have a reference to size. http://i206.photobucket.com/albums/b...ound-round.jpg Cheers Paul |
Hi All
Here are a couple of photos showing the actual size against a steel rule and also the two LED's sitting in place. http://i206.photobucket.com/albums/b...140920_004.jpg http://i206.photobucket.com/albums/b...140920_002.jpg I am thinking of making the round ones a little bigger, at the moment they are 22mm X 12mm, I am thinking 26mm X 14mm will be better. They will look good on an Early White Road Boss or Western Star with the right Grill or a KW K124 and W900 with the old KW grill......... Cheers Paul |
Hi All
If I can get a bit of feedback on this it would be great I have been asked to do a set of light bezels for the single headlight type as seen on KW T950 or Western Star 4800/4900 series, the individual round type using two each side. The outside dia. is 16mm, is this too big? it will fit the King Hauler headlight area ....just.... reason I did them so big was to take the std spot light lense. if you think they are too big please let me know cheers http://i206.photobucket.com/albums/b...undISOview.jpg http://i206.photobucket.com/albums/b...dfrontview.jpg http://i206.photobucket.com/albums/b...ndsideview.jpg |
Update:
Have made an addition, its the same round twin Bezel but it has now got 12mm lenses in place of the 10mm lenses. |
Price Update:
All Light are now $20AUD per pair plus postage I am also making the LED hole 3mm as STD, if you want 5mm it can be easily drilled out. |
Hi Paul I'd like a pair of these
Cheers Bob |
Please PM me if you would like to place an order
