Old 12-21-2013, 01:36 PM
Default Re: 777 HAUL TRUCK (1/12 size)
Originally Posted by DADSGARAGE View Post
Thanks...( I didn't get a video when I was trying it out the other day, the steering set up does have enough power even with 60lbs of weight in the box, but this is on a flat concrete floor...dirt could be a different story.I just have foam in the rear tires and the 60lbs was really flattening them out but it still seemed to turn OK , but I think the rear tires might be slipping on the rims)
A PC5500 in 1/10 would be awesome!!! If you build it you almost won't need your mini ex. anymore. What about the PC3000, just a bit smaller
http://www.equipmentcentral.com/nort...nt/ACF1184.pdf
I think a 1/10th 5500 would be a little hard to move around but you are right, I could probably sell my Kubota!lol I have been planning a big Euc R18 in my head for a while so the shovel may come in handy some day...
Instead of running foams in the rear tires, couldn't you just put the valve stems in the center between the duals?
