Old 01-18-2014, 01:49 AM
DADSGARAGE's Avatar
Default Re: 777 HAUL TRUCK (1/12 size)
Originally Posted by doodlebug View Post
Well I confused beadlocks with screwing the tire to the rim , what about a backup ring inside the tire bead to take the screws? Yah blue balls are simpler they're the right color for being overloaded
If I understood customs a little better, I would offer to send the tire's into get
"stuffed"
Cheer's, Neil.
You might be right about the color....being overloaded...
The spacers I cut from plastic are not a true beadlock......just a way of keeping the tire in contact with the rim...originally I had hoped the tires alone would be enough to carry the load without the air filled tubes but the side walls are too thin....so being that I will only have tubes on the inside tires on the rear duals I needed to make the outside tires look the same somehow (the air filled tires are taller)....and the racquetballs seem to be a way to solve the problem....hope this makes sense......
