Old 02-03-2014, 05:35 PM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Re: Total newbie dozer process
Thanks!
I can't believe the JB Weld holds. I have done servos on my crane that way, but I tap the rod and then run a jam nut onto the servo. Sometimes I drill a cross hole and put a pin thru it as well. I'm going to have to try the JB Weld method.
Is it a pretty tight fit or don't you worry too much about it, expecting the JB to hold it?
Jim
