Old 02-08-2014, 12:35 AM
Lmackattack's Avatar
Default Re: Rc4wd down shift trans ?
Yea I have not used it either but the 540 style can motors have a standard bolt spacing for mounding.. I see in the discription it has a pinion gear that comes with it... You will need to use the pinion that comes with it as there is no adjustment slot if you plan on using a smaller or larger pinion gear...
Yes...The black thing looks to be a motor in front of it.....it looks like it mounts to the top of the frame...it likely sit up about as high as a stock motor does...
You should be able to pick any 540 motor install the pinion and bolt it up to the transmission.
If you are currently using a stock tamiya motor and trying to get the truck slowed down try a 55 or 65 turn motor. Higher the turn slower the RPM.
