Old 03-28-2014, 11:48 PM
Cooper's Avatar
Cooper Cooper is offline
Didn't know that about the lateral tilt cylinders. Thank you. I will still need the fifth valve for the independent tilt cylinders,? Right? If I'm following you. The mixing shouldn't be a problem as I'm fairly familiar with setting up mixing. Not sure about assigning a slave to all functions for the pump to only run when needed. But I'm sure I'll figure it out when time comes. Like when it's all together and then you can't figure something out so you tear it apart to put it back together different just to realize it was a simple switch or program that would have solved it!! Keep ya familiar with how to put something together even though you built it! Lol!! Murphy's law or just looking at a T-bone steak by sticking you head up the bulls a$$ !! Lol. I'm using a turnigy tx9 radio, have spectrum 6i also but I'm pretty impressed with the tx9 (for the price)
