04-19-2014, 05:26 PM
Re: First build ,cat D11
Originally Posted by Cooper
Question, it's pretty oblivious to me but just wanted to be sure. On the cylinders, for the hose fittings to properly seal should I machine a flat spot where the threads are? I'm thinking with the plastic sealing ring on the fittings they will need to have a clean flat surface to seal properly. Correct? I'm onto finishing up with the hydraulics and clarifying all those little details that seem to drag on a build.
yes, then put a lil thread sealant on the threads and you should be good .
