Old 04-25-2014, 12:23 AM
hvy 1ton hvy 1ton is offline
hvy 1ton is on a distinguished road
You need one of these for the Bell. http://www.bultequipment.com/PDF/Tit...-Wheel-Pan.pdf
Doubles need minimum of 4 circuits and 2 sequencing valves. The sequencing valve allows the apron and ejector to run off the same circuit. Otherwise both pans will try to load at the same time.
