Old 11-14-2010, 08:23 AM
Brian in PA's Avatar
I'd rather be truckin'
Default Re: New build, Pete 357 tri-axle dump
Thanks guys! Scott, yeah its an illusion, The front tires are actually the same height as the drives, but they are 22.5 and drives are 24.5 the sidewalls are thicker on the fronts. This probably helps with this illusion. Thanks!
Brain
