Old 07-09-2014, 07:09 PM
apfubar apfubar is offline
Default Re: Servonaut Sandmaster GMK 4000
Basic stats:
Scale: 1:14.5; Length: 645 mm; Width: 296 mm; Height: 300/222 mm; Tires: 132 mm; Empty weight: 9,3 kg; Total weight: 25 kg; Stall power: 20 kg (with spindle drive)
Perhaps the biggest surprise of the Model 2013 presented tematik ago on the model-hobby-spiel in Leipzig. The first complete model of Wedeler Electronics Forge is a milestone in the successful history. Accordingly, anxiously waiting many modellers on the delivery start Komatsu HD 405-6 in April / May 2014. Handsome dump truck is 645 millimeters long, 296 millimeters wide and weighs approximately 9.3 kg empty. The vehicle frame is welded powder-coated steel, the cabin is made of PVC. Two drive motors with planetary gear on the rear axle provide sufficient power to on construction sites and in rough Terrain to get along well. The rear wheels run on 55-millimeter thin section bearings with rubber seal. the Spindle drive for the trough made of steel and aluminum is fully mounted and wired together with the associated motor supplied.
From February edition of Rad & Kette
Cheers,
Ap
