Old 11-19-2010, 04:57 AM
Bodyman Bodyman is offline
Bodyman is on a distinguished road
Default Re: Help with a bandsaw
use cauction on the dimmer for a motor. the dimmer will reduce the volts going to a
motor which will slow the motor, but with electrical, volts goes down,amps go up
and you could be overamping the motor. so if you do this get a amp meter
and check. over amperage a motor will burn it out over time.
