Old 08-08-2014, 09:56 AM
PaulNZ's Avatar
PaulNZ PaulNZ is offline
Default Re: Tilt nose Pete 379
Originally Posted by Kaf343 View Post
Thanks Mike,
I'll post some pics of the hood hinge, I use brass flat plate 1/2" x 2" bent to 90degrees, solder a piece of 1/8" ID tube to it, drill and tap the bottom of the grille and mount the plate to the grille. Then I use two pieces of brass 1/4" x 1" with three holes drilled in them, mount the two pieces to the front spring hanger and then use a 2-1/2" piece of brass rod to slide thru all three pieces. The bottom of the grille needs to be notched a bit as well.
Great work with the tilting Hood, how close are the guards to the air cleaners when you tilt it? have you lengthened the bonnet?
cheers
Paul
