Old 09-01-2014, 11:10 PM
ricm ricm is offline
Default Re: MFU Coupler Switch: Required?
Originally Posted by Rick.K View Post
I'm going to find a way to mount the coupler switch just in front of the leading edge of the coupler, and on the frame, so that when the 5th wheel tips forward as the trailer slides on to the 5th wheel the coupler switch will be engaged. This way I retain the sliding bar under the 5th wheel the actuates the trailer landing gear.
I would suggest you stick with the original Tamiya design - it works fine - if you mount the switch as you suggest you'll get constant coupling/ uncoupling sounds if you drive over an uneven road surface, as the 5th wheel moves relative to the tractor truck chassis...
