Old 09-12-2014, 03:22 PM
mamwr mamwr is offline
mamwr is on a distinguished road
Default Re: New King Hauler Project
Originally Posted by bigford View Post
my dx6i i kept the spring off works like cruse control for me
with a 65 and 80 turn in my trucks there slow enough for me
to correct and problems
Hi bigford you raise a good point. I haven't actually driven it outside yet, only inside in a tiny space about 3x the size of the truck. Perhaps I'll try out without the spring first and see.
Originally Posted by flatdeck View Post
On mounting the fenders. the larger bracket (should be 2) will slide into the frame rails. one for each end of the fenders, the four "L" brackets attach to the inside of the fenders along the lower side of the fenders ( the slot side will go to the frame bracket for height adjustment) then you use the hardware you got with the kit to attach the "L" brackets to the frame mounts . You will have to do some trial fitting to make sure they are where you want them before attaching them to the fenders.....
Hope this helps
Thanks flatdeck. It took me a while but then i finally got what you meant ha! So they just wedge in there then? I guess the fenders aren't exactly the heaviest of things in the world.
Originally Posted by Cossett View Post
My dx6i came with a gimbal centering kit
and the two types of metal strips
the smooth one is for the spring kit,
there is also how to you tube videos or you local rc shop should be able to do it, but most people usual have one spring loaded,
Also in the dx6i manual there are instructions for changing a mod 1 to a mod 2 and vise versa so you can have the spring stick on the side you prefer when you go into the program settings
Cheers Tracy
Thanks Tracy. I will try it without the spring in first when I finally drive the truck outside once all the mods are done and the trailer built. I just had a reply from horizon hobby who distribute that radio in the UK and they said they can send me the kit for about £7.
