Old 10-01-2014, 09:29 AM
PaulNZ's Avatar
PaulNZ PaulNZ is offline
Default Re: Freightliner Logger - Built By PaulNZ
Bit more progress with the trailer design.....next start building from Aluminium most parts will be cnc cut and drilled.
Trailer will take the std 2 axle set without the shocks.
Should be able to carry 1000mm logs with this set up and still get it on the back of the truck..... that's 14.5 meters at 1:14.5 scale.
If I am carting full length stems then they can overhang
