Old 10-10-2014, 11:33 AM
PaulNZ's Avatar
PaulNZ PaulNZ is offline
Default Re: Freightliner Logger - Built By PaulNZ
Originally Posted by Trucker_Jo View Post
That looks good!!
Thanks Jo
........still a lot of work to be done but its getting there and I'm pretty happy with it too
As you can tell by the pipes it is a fair bit longer, should be able to cart full length stems at @ 1200mm long with only a small overhang (that's 17.4 scale Meters or 57 Feet)
If I follow what they do in the real world I would be looking for trees 1500mm long. (21.75Meters or 71.36 Feet) I cant remember what the stem length was that they are carting, someone will know
found a use for a few of the hooks from the kit also, I will also put one on each corner of the base of the Bolsters also to chain the load down.
now to go and find some trees to cart......................
Cheers
Paul
