Old 10-12-2014, 08:19 PM
Default Re: Fumotec Komatsu 490 LC build
Originally Posted by Rakthi View Post
Yup ... had to do it all over again because I forgot the 3D printed cover ...
Cheers
Stephan
I had a BOL (big ol laugh) at this knowing what a bytch it is to line up the bolts with the several series of different holes & the spacers in the bridge too, not an easy trick to accomplish with big fingers.
I'm about as far as you are now & will get back to building again shortly. I went with 5valves & that required some redrilling of the mounting plate to fit beside the pump, hopefully I can still fit a 4s lipo on the left... might have to do a little surgery on the cab.
