Old 11-21-2014, 10:21 PM
The Premacon hyd kit has a Jung pump capable of 100bar. The pump motor is properly gear reduced so the brushless motor & pump run at correct speeds & the esc won't be maxed out in Amps or heat. And the Meinhart rotary valves are just far superior in smooth oil flow.
I think this model's overall size is moreso a 345 series.
Does the track motor upgrade have planetary reduction? I don't think spur gear will hold even with a drag brake in the esc.
What bore size cyls were you thinking of making?
