Old 12-09-2014, 07:01 PM
Tamiya Cowboy's Avatar
Default Re: Bulk Food Grade Tanker Mirror Stainless.
I made the pointed end caps by cutting out a circle out of alum "witch ill sand and polish" the cutting a slit from the edge to dead center then started forming to get the shape I wanted then using special auto body metal to plastic glue set it on the inside of the outer tanker skin..
Then using my roller I rolled sheets of mirror stainless from KnS tighter then they need to be for a tight fit and fixed them into place on the bottom side with 1.5 grub screws.
Going to try to stay about 98% metal or alum other then the inner tank on this and I will stick to the little more show side of a stock tank..
Ok more to come..
Paul W. "Tamiya Cowboy"
