Old 12-27-2014, 10:54 PM
Default Re: Dx8 channel mixing help
If we're talking about an excavator here, Master is the valve channel, Slave is the pump. Throttle = boom, aileron = bucket, eleveron = stick, gear or 3 = pump. I assume you'll be using Aux1 & Aux2 for tracks.Then there's getting the +100 & -100 values in the right order, depending on how you wired the esc to the pump. Mix 1 throttle/pump, Mix 2 aileron/pump, Mix 3 eleveron/pump
