Old 01-17-2015, 07:10 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
Default Re: Scania side lights help
I have seen an acrylic block machined square to fit through the body to sit slightly proud or flush. The hole for the LED was drilled at 90 degrees for indirect lighting. Then the block was then coated in reflective paint but could be foil or something easier.
