Old 01-23-2015, 07:24 AM
Default Re: Hayes HD Dump Truck - Take II
A tiny bit of progress after hours of work.lol There is a reason people that build and sell wheels have CNC machinery. I would say that I am about halfway on these wheels after two full days. Next up will be machining the beads(not the kind Mario uses) and then I will do some more work on the hubs to make them look more realistic. I have started making my own axle housings(Rockwell 4640) for this but I am unsure at this point if i will use them. Once I decide what I am doing with that I will either cross drill the hubs for a set screw and a blind axle hole or machine a hex into the back for the stock axles, drilling right through and using a cap on the hub.
Thanks for looking!
Look great Reg . Yes , the CNC is necessary for wheel production otherwise you go crazy
