Thread: RCP Compound
Old 02-09-2015, 08:49 PM
Default Re: RCP Compound
OK, so I ditched the first conveyor in favor of what I had wanted to do in the first place. I've had a nasty cold the last few days so I decided to take it easy and use the long weekend to get started. This one is quite large at nearly 5 feet. The belt is 3 1/2" wide. The treadmill I used still worked but was slightly disassembled(controls were off). I thought it would have had a brushless motor but it turns out to have a 90v brushed motor instead. This worked out awesome as I was able to power it up with 12v and cut the strip off with a razor blade. I just held the blade steady and the treadmill did the work! What I have done so far is very basic. I have yet to make any rollers other than at the ends but it still runs pretty true. I have a ton of work to do on it yet so this will be an ongoing project.
http://youtu.be/eKVmfTlKWbA
