Old 04-27-2015, 08:18 AM
dozerbuilder dozerbuilder is offline
dozerbuilder is on a distinguished road
Default Re: Miniature plow-bolts for cutting edges/routers
Solved. This may be of interest to other builders looking to have realistic plow-bolts on GET. Thanks to the heads up here and PM's, it turns out they are called Rivet Head Screws and have the desired shape. Here's an example I found scrounging around on the net after I learned what they were called. These are M2 and resemble a plow-bolt good enough. This seller wants minimum order of 5000 so I'll have to look around for the 60 I need.
