Old 06-15-2015, 03:39 PM
modelman modelman is offline
Default Re: Dragline Crawler Build
Jim-if the 10-t sprocket is okay for size then maybe you could use the same on the motor. When you get a little farther along you can turn the assembly and calculate the speed you need and get a motor that speed. If you get a slow motor it should have a lot of power. Just a thought- keep at it!!
