Thread: JBC limited NZ
Old 06-24-2015, 11:23 PM
Default Re: JBC limited NZ
if learnt something today, if you use a mig welder to weld galvanised fence wire you are lighting a fuse.
Ive welded galv steel before and its not that great, clean the galv off and its not too bad. but the wire just started burning and fizzled out about 10mm shorter than what I started with.
plan B was needed , I had a length of tig welder filler.
cut and bend to suite and weld with mig , works nicely.
Unfortunately I only had 1 length so got to get some more to finish the safety rails.
Bob seem impressed with the crusher.
this is where the main conveyor drive will be
rocks come down this way
safety rails, check .
I have no idea what he's up to in this photo, I think he wants to be fired even before it has run.
time to light the fire , its way too cold to be in the shed.
cheers andy
