Old 07-05-2015, 12:18 AM
Rakthi's Avatar
Rakthi Rakthi is offline
Default Re: Scaleart - assembling an Arocs 8x8 roll on roll off kipper
On with the next group.
We start of with the windscreen. This could not be installed earlier otherwise wouldn't be able to attach the intake.
Consists of a window, front cover and 3 self tapping screws
The window needs to be bend a bit to get behind the sides. Also need to be aware of good positioning at the roof. I got mine stuck wrong on one of the screws of the visor. And I got some paint damage in the lower corner form not paying attention when bending/inserting it. Lucky the black cover goes over it.
Gets all fastened on the inside. Access through the bottom. Was very happy with the bendable extension I have. Was worried the screwdriver would jump and scratch the plastic.
Next the floor parts. Assembled with countersunk screws.
No way I can glue the optional carpet on when installed in cabin ...
So attach the needed screws. Already complicated enough getting the "carpet" on straight without having to deal with screws all over the place. (Carpet can be repositioned if not right first time around)
Both side pieces attached first, and the center piece goes in from below. Had to loosen the nuts from the side pieces to make it easier to get the center bit in place. Very tight tolerances.
Continued ...
