Thread: JBC limited NZ
Old 07-28-2015, 02:59 PM
Default Re: JBC limited NZ
Hi calum.
dont have any pictures of the crusher plate.
what I did to fix the bottom was drill and tap some 6mm holes at the bottom of the crusher plate.
I then used some 6mm bolts ( quite long) and put some heavy compression springs in between the plate and crusher box.adjusted lenght of spring to get correct angle on plate.
you will have to slot these holes through the box to allow a little up and down movement
job done.
cheers andy
