Thread: Scania 8x8 dump
Old 09-08-2015, 01:52 PM
Digger_Bear Digger_Bear is offline
Digger_Bear is on a distinguished road
Default Re: Scania 8x8 dump
Originally Posted by SmallHaul View Post
Nice truck. Should be hard to get that one stuck.:-)
Sealing the lesu tanks that have caps on each end that leak.
Drain the oil out.
loosen the set screws that hold the end caps on and remove end caps.
Clean the inside of the tank and both end caps well with rubbing alcohol.
Using clear silicone caulking place a bead of it all around each end cap over the rubber O-ring and push the end cap back on.
If you put enough silicone on it you will have silicone that oozed out the edges of the tank that can be wiped off using rubbing alcohol. Remove the excess silicone right away and it will all come off nicely. Let the tank sit over night. It won't leak again.
Great thanks for sharing. I've decided I now want one of these so asked my friend to source one to me here in the UK.
