Thread: Fumotec 490
Old 09-22-2015, 03:05 PM
calum_scania's Avatar
calum_scania calum_scania is offline
calum_scania is on a distinguished road
Default Re: Fumotec 490
WOW!!! Congratulations Calum, quite an enjoyable model to put together for sure.
I put in a 5 valve block & it seemed to spread nearly the entire width... 6 will be tight!
I also use a 3s 5000mAh lipo from Team Enrich-Power that measures 135mm x 42mm x 28mm
The hyd pump that comes with this model is ridiculously fast & with such small bore cyls, cycle time is very quick! even with the motor rpm at 50%. I set my pressure to 18bar, seems plenty to keep the model planted while digging.
Good luck with the build, hope it goes together easily for you.
Yes so far its been excellent to build, everything fits so well and looks well made too!
I asked Frank about a 6th valve and he said it should be fine, hopefully it will work for me..
I remember you saying about your's been a little quick did you ever change anything or do you just use it like that?
I shall have a look at that battery too
Thanks Calum
