Old 10-26-2015, 08:41 AM
Hi Marquez81,
Thanks!
I'm not sure if I understood you correctly, but if you ask if I plan to do the same as this for the rest of the components of the excavator, then the answer is yes. (even if I'm in that phase of the project where it dawns on you just how much work that is left... ;-). Just got to make sure to have a little bit of progress every day, and it will get done eventually. )
Best regards,
Stein :-)
