Old 12-07-2015, 02:06 AM
Rimrock Rimrock is offline
Default Re: Magom D11 hyd ram ratings?
Originally Posted by dozerbuilder View Post
Hey thanks Rimrock. That's a great help. And that's their smallest bore size as you mentioned. They have 18 and 22mm bore too - need to check with them as you advise re sizes of the D11 kit but even the spec for the 12mm looks good + quite a margin of reserve capacity. I'd probably go with 4 x 22mm for the 4x barrel ripper and tilt and maybe the 18mm for the blade lift. I'll check with them as Lil Giants and yourself has suggested. Not sure if they communicate in English but no doubt will find out soon enough.
Thanks.
Yeah they have the larger rams too. The dimensions are given on their webpage, so you can evaluate what sizes looks better visually on your dozer. They communicate in English.
