Old 12-22-2010, 05:25 AM
Katan Katan is offline
Katan is on a distinguished road
Default Re: What would be the perfect powered front axle.
Originally Posted by ihbuilder View Post
Katan , the reason I'm asking , Is I make scale suspensions in my trucks . The way they are set up , the stock tam axles will not let them function right being that the case is to bulky . basically I need thinner axle tubes in the frame area .
IHSteve
You got any pics or specs to help me understand and see what you need?
The D35 axle has 15mm OD tubes. Our rear axle has 12mm tubes.
Would a middle axle with two outputs that matches my rear axle be what you need?
