Old 12-22-2010, 07:34 AM
Default Re: What would be the perfect powered front axle.
Originally Posted by Katan View Post
You got any pics or specs to help me understand and see what you need?
The D35 axle has 15mm OD tubes. Our rear axle has 12mm tubes.
Would a middle axle with two outputs that matches my rear axle be what you need?
Katan , I'll have to take a pic of the real set up but could take awhile , till I get the truck out and take wheels off to give a good pic . 12mm will work ,If I'm the only 1 then perhaps I can modify for my needs . just would be nice to be able to get the complete assembly unless yo can buy just the tam diff and pinion .
this is on my Paystar 6 x 6 rotator , the tam axle works somewhat ok because the whole truck sits high in real life . the axle goes between the frame and walking beam and till I put the hanger under the axle It dose not give much clearance to the frame
IHSteve
