Old 02-14-2016, 02:20 AM
steamer's Avatar
steamer steamer is offline
Default Re: 6X6 Quarry Dump Truck
Just a suggestion on you screw drive. On mine I found that the furniture drive nuts didn't last long being metal on metal. I just replaced the slider block and drilled and taped right through with the thread. Delron itself is very slippery and I find I can lift a bigger load faster with the new block. One thing though is you have to have a very sharp tap as it doesn't cut the best if it's dull
Rob
