Old 02-16-2016, 06:26 PM
SmallHaul's Avatar
Default Re: Mack DT 3rd rebuild
Originally Posted by Claus View Post
Scott how is this truck holding up after all these years? Have you ever broke any of the drivetrain? Are your axles locked?
One of the Classic builds.
It is holding up nice Craig, the only thing that i had to do it lately was re-glue a couple of tires that spun loose.
The axle are all modified with rubber washers in place of the metal shims in the diffs. The rubber washers force the spider gears together so hard that it acts like a posi rear end but, if you are carrying 15 pounds of dirt and turn sharp the spider gears will turn.
You can really see them all turn in this vid @ 3:50 mark.
https://www.youtube.com/watch?v=_H-dIBU6laM
Last year i had to open one axle up because the posi action was gone and i found the rubber washers were ground to shreds. So, i cleaned it out and made new washers for it. I just took both of the axles out of the king hauler after the Cabin Fever show and did the rubber washer mod to them as well.
Originally Posted by Bo Wallen View Post
Looking Good Scott. I like that old workhorse keep going Sir.
Thanks Bo. :-)
Scott
"No load is too Small"
