Old 02-16-2016, 09:29 PM
SmallHaul's Avatar
Default Re: Mack DT 3rd rebuild
I should also add that the tight fit of the rubber washer against the backside of the bevel gear and diff housing also contributes greatly to preventing the spider gears from rotating..it is not just the pressure on the spider gears that makes the mod work. Which is probably why the gears seem to be holding up fine.
Scott
"No load is too Small"
