Old 03-04-2016, 05:25 PM
Default Re: Metso Lokotrack LT120, Jaw Crusher.
Really Neat!
I really like the timing belt and drive sprockets, but do you think that plastic roller chain and standard chain sprockets would hold up or would there be too much stress and vibration in this application?
I'm asking because if I attempt something like this, it would be much easier for me to use roller chain and buy sprockets vs machining timing sprockets. Also, where did you find the timing belt?
Thanks for the pictures!
Jim
Thanks!
This timing belt is really strong, I would be suprised if it would tear apart.
Both belt and pulleys are from Maedler.de.
Originally Posted by 9W Monighan View Post
How did you join the conveyor belt? Do you have any pictures of that and what exactly is the belt material? Cloth reinforced rubber?
I did join the belt with a glue called Liquisole, I got it from my local food store, its a really common glue around here, got a very strong joint from it, and the joint is still flexible.
The belt material in Neoprene rubber 1.5mm thick.
