Old 03-09-2016, 08:41 PM
Default Re: Russian ChTz T-800 1/16th scale Bulldozer model
Originally Posted by dozerbuilder View Post
I personally are not too happy about the possibility of oil leaks and also having high pressure oil in the mix. I like the controllability of the RC actuators - plenty of adjustment available in the RC mixing and the ESC's.
Cheers
My Stahl 742 dozer was more than 13yrs old when I took it apart last fall, never ever had an issue with an oil leak & never needed the pressure to be that high either, just enough to lift the nose off the ground so the blade would dig in. I took it apart b/c some parts of the u/c need rebuilding.
