Old 03-24-2016, 01:59 PM
Markus K. Markus K. is offline
Markus K. is on a distinguished road
Default Re: 1/10 Liebherr Excavator R 984 Litronic
by the way, why do you need open center valves? You might run into problems, when using two different motions at once.
And you simply can "simulate" an open center valve by using an additional closed center. You just have to mix it to your working valves in that way, that it opens just in the moment when you don“t use the hydraulic.
