Old 04-29-2016, 06:41 PM
Added a simple mount for the brain (CPU) of the excavator. At the same time I replaced the Raspberry Pi 2 with the version 3. It's mostly the same, but a little bit quicker and has WiFi and BlueTooth built in.
- Raspberry Pi 3
The mount is very simple. Four self-tapping screws to hold the PCB and then two nylon M4 bolts to hold the mount on the base plate.
The audio (engine sound) has its output through that 90-degree 3.5mm jack on the top.
