Old 05-22-2016, 02:40 PM
cosworth34677's Avatar
Default Re: good dozer gear motor
true, but not true........ some 12v motors and run fine on lower volts but you would not get the full power that a full 12v will give you. the other thing is that sometimes you can burn out
the motors if if they are running to low on volts. but that's kind of rare. but to be safe it would be better to run them on 12v's.
