Thread: Fumotec 490
Old 06-13-2016, 12:11 AM
Rakthi's Avatar
Rakthi Rakthi is offline
Default Re: Fumotec 490
Hi Calum
I have the Servonaut MFR on the fast setting, so takes only a very limited movement of the stick to make it go slow (and scale) enough to keep control. But there is some play in the whole slewing mechanism.
As for the pump ... The way it is set up in the Commander from Scaleart, you can control the speed of the pump with a separate control which allows you to set the speed of the pump, independent of the mixer which will make the pump go faster depending on the opening of the valves.
I have the pump running at maybe 10-15% of it's capacity at all times so there is no lag when you start opening the valves. Seems to work fine for me, even when operating more than one valve.
