Old 06-29-2016, 03:03 PM
TRUCKMAKER's Avatar
Default Re: Short dumper box?
Originally Posted by TheBennyB View Post
Yea, if the bruder doesn't work out I'm take your suggestion on the plywood and bass wood route. Never thought thick CA would hold up to impacts like a box may encounter, thanks for the tip.
If you put a good bead of CA between the 2 pieces then come back and put a fillet with thick CA on the seams and hit it with kicker, its just like a weld joint on steel. If done right you'll rip the wood apart before the joint. I also CA a piece of aluminum channel on the top edge of the box sides so if the guys hit it with an excavator bucket or loader it wont chip the wood.
