Old 08-13-2016, 04:10 PM
Supermario's Avatar
Default Re: i am over this hydraulic excavator stuff!
Did you open up the old pump after replacing? Did you find anything wrong with the valve while re sealing? Just wondering what original cause of drift and low power was? Pump failing causing metal to go through system? or valves not centered or too much internal leakage?
