Old 08-27-2016, 05:43 AM
Default Re: Nylint michigan crane conversion, hopefully
As an alternative, for the slew and pinon gears, maybe you could use something like this:
- Pinion: http://www.ebay.com/itm/151889646562
- Slew: http://www.ebay.com/itm/161891095040
You can see they have almost all types of bores, mods and number of teeth:
- http://www.ebay.com/sch/m.html?_odkw...+gear&_sacat=0
If you select a 4mm bore, then you can use a gear motor like this one:
- http://www.ebay.com/itm/381486411254
60 RPM / (66 teeth / 12 teeth) = 60rpm / 5.5 = 11 RPM
11 RPM for the swing would be quite ok, I think.
Best regards,
Stein :-)
