Old 12-06-2016, 01:21 PM
Default Re: Large diametre Aluminium Rod
Try Clinton Aluminum in Ohio USA
Order flatbar the desired thickness then, You may be able to bandsaw cut your round from plate slightly oversize then turn in your lathe.
I miss read your post.
You want large quantity. Check with supplier I mentioned. I don't know where my extrusion suppliers get their billets.
But that may be worth checking into. They buy rounds in various diameters to use in their presses.
