Old 03-17-2017, 11:40 PM
Default Re: VW bay-window transporter
I picked up a horizon hobby SPMS401 mini servo. Trimmed away stuff until it fit. I punched a servo mount ear through the right wheelwell and built up a stack of styrene to secure a screw. I mounted the other ear to a styrene plate that i brought forward and screwed into the tunnel between seats. Draglink needed a little clearancing and an oval hole for the servo since i'm using the wrong arc of its swing
Trim seats for clearance.
While i was in there i also raised the steering knuckle supports by a bit less than the amount hanging below the knuckles. Clearanced the supports that tie the front and middle of the pan so the draglink could articulate. Drilled through the stop plates above the steering knuckles so they can articulate up.
I'm going to drop some pen springs in the front and cap the top. Or maybe i decide it has drop spindles and forget to do it.
Then i loosened the forward transaxle mount screw, and put springs between screw head and transaxle at both rear mounts.
