Old 04-03-2017, 07:36 PM
Default Re: Dozer control question.
Does your radio support Elevon mixing?
Elevator up/down for blade up/down. Aileron right/left for blade pivot. With each cyl on its own valve, you should be able to run them both mixed or straight as needed. Probably easier to run them on 1 stick, and the other stick for drive.
