Old 07-23-2017, 07:37 PM
Default Re: locked differentials
I just remembered another limited-slip option a lot of 1/10 scale crawlers run where Open doesn't work, but you don't want turning radius of Spool.
Silly Putty.
Clean the carrier and gears. Figure out how many eggs you need to pack diff. To loosen the amount of lock, add silicone shock oil. Work in a couple drops of oil to the putty, assemble enough to test it. Go slow adding oil, or you'll have to add more putty to thicken again.
